Adge66
Jan 27, 2019Follower
Connect to Orbi, but Outlook doesn't work
I installed a new Orbi system this weekend. I pulled out the old Apple AIrport Wi-fi. I connected from the Orbi router to my Fios router via the ethernet cable supplied by Netgear. Here is my situ...
PerkC2
Feb 18, 2019Aspirant
We are having the same problem. My husband hasn’t been able to work from home since we purchased this last month since it won’t load his Outlook 365. Really disappointed.
CrimpOn
Feb 18, 2019Guru - Experienced User
So, the impression is that Outlook 365 was working great. An Orbi was purchased and directly replaced something. (Or, was it simply "added" without replacing anything?) Now, everything except Outlook 365 is working, but Outlook 365 is not. Correct?
Perhaps it is worth "starting at the beginning." Before installing the Netgear Orbi:
Outlook 365 "worked fine"? (yes/no)
Internet service is provided by?
What brand/model of WiFi device was being used before (that worked)?
Was the WiFi connected directly to the internet, or did it connect to something that the Orbi is now connected to?
What brand/model of device is this?
How is Outlook 365 being accessed? (computer? (PC/Mac) Which browser? (Chrome, Firefox, Edge, IE, Safari)
Your situation may not be exactly the same as the previous discussion.
- ekhalilFeb 18, 2019Master
Whenever you have issues with specific apps not working, that is specific ports not reachable, then think of double NAT (double routers in the network).
Please make sure that your ISP modem is not a router, if it is then please make sure it's bridged or set in DMZ forwarding.
If you can't change anything in the ISP router then keep it as your router and set Orbi in AP Mode.
A simple and quick way to test if you have double NAT is using traceroute.
Please open a Command Prompt on any computer attached to Orbi and type:
> tracert 8.8.8.8
Look at the result printout, If you see two private IP addresses listed in the first two hops then you have double NAT. If you see only one private address and the second hop shows a public address, then you’re all good. :)
- PerkC2Feb 19, 2019AspirantOutlook worked fine before we switched to Orbi
Internet service is HughesNet satellite (not great internet but our only option in the country)
We were using a TP Link AC 1750
Router is connected directly to HughesNet modem
Product is Orbi RBR 20
Outlook is accessed on PC laptop using Chrome- FURRYe38Feb 19, 2019Guru - Experienced User
Try a different browswer, IE11, FF or Opera to see if they experience the same problem.
Also try a different PC or laptop or mobile device to see if this happens there.
Is the Orbi system operating in Router or AP mode?Try setting DNS on the Orbi to 1.1.1.1 and 9.9.9.9
Outlook is accessed on PC laptop using Chrome- CrimpOnFeb 19, 2019Guru - Experienced User
Regarding the problem posed by @PerkC2 , Hughesnet offers several different modems. Which one do you have? And, just to confirm, the TP Link modem was set to act as an Access Point or a Router? i.e. The Orbi is set to the same mode as the TP Link was?
And, everything except Outlookk 365 is working fine?
