loremipsum's avatar
loremipsum
Connect to router (RBR50) with ethernet
I am able to connect to the satellite with an ethernet cable; however, I am NOT able to do the same with the router. For a wired connection do I need to set my laptop's IP to a particular static IP?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello loremipsum
    What is happening with your wired connection when plugged into the router? Do you not get a IP address on your laptop?
    DarrenM
    • and have you tried all 3 available lan ports on the router , i did have a strange issue at one time where one of the ethernet ports wouldnt work , i think it was port 4
      • loremipsum's avatar
        loremipsum
        I did try two different ports. When I was connected I couldn't reach the router's login (orbilogin.com) or get any website to load.
