MarkWorsnop's avatar
MarkWorsnop
Connected devices shows wired on my LAN. V2.0.0.74
Why do I see all the wired devices on my LAN that are NOT connected to the ORBI?  They all say wired.  Its nice to see this, but that are not connected directly to the ORBI and is really misleading.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello MarkWorsnop
    If the orbi is your main router it will be assigning IPs to all those devices so it would show up in the attached devices.
    DarrenM
    • MarkWorsnop's avatar
      MarkWorsnop
      ORBI is NOT the main router. It would make sense then, but its not
      • DarrenM's avatar
        DarrenM
        if its not the main router do you have orbi running in AP?
        DarrenM
