wiwizam
Feb 20, 2017Aspirant
connecting 2 xbox one consoles in the same orbi network
Orbi network works OK when I have one Xbox One connected to the wifi network. However when a second Xbox One connects to the same network one of them has issues to connect or disconnects frequently. Is there any special setting I need to do to avoid this?
- DarrenMSr. NETGEAR Moderator
Hello wiwizam
You may need to do port forwarding for the xboxs.
DarrenM
- wiwizamAspirant
Thanks DarrenM,
I activated UPnP based on the article you shared. I need to track how it works for a few days as my kids don't play that often simultaneously with the 2 Xbox One consoles connected to Xbox live.
If this does not work, I will try the port forwarding option although if I will probably need some guidance on how to get that working.
Thanks again
