bdotn
Jan 02, 2019Aspirant
Connecting HP 8710 wireless (ORBI) printer from FIOS Router connected device
All - I recently bought the ORBi Router and two satellites to fix some Verizon FIOS deadspots in the house. Works great !! Netflix downloads are wicked fast. Anyways, I set up my HP8710 wireless p...
Jan 02, 2019Guru - Experienced User
The FIOS and Orbi are on two different submets that you can't communicate accross. You need to get the game and laptop PCs connects on the same subnet as the printer.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Connect ALL devices to the Orbi router.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode. Connect ALL devices to the Orbi router.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. Connect ALL devices to the Orbi router or FIOS router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- bdotnJan 02, 2019Aspirant
Thanks. I am going to call FIOS and explore their support. otherwise, I'll go all wireless. I will udate the post when I learn more.
ahhh I need my head examined. I unplugged the wired connections to the FIOS router and replugged them into the wired connections on the Orbi router. SUCCESS !!!
- FURRYe38Jan 02, 2019Guru - Experienced User
That works too. You can use that configuration.
IF your don't bridge the FIOS, i would use the FIOS DMZ for the Orbi router if your using it in router mode.
Enjoy. :smileywink:
