bdotn
Jan 02, 2019Aspirant
Connecting HP 8710 wireless (ORBI) printer from FIOS Router connected device
All - I recently bought the ORBi Router and two satellites to fix some Verizon FIOS deadspots in the house. Works great !! Netflix downloads are wicked fast. Anyways, I set up my HP8710 wireless p...
bdotn
ahhh I need my head examined. I unplugged the wired connections to the FIOS router and replugged them into the wired connections on the Orbi router. SUCCESS !!!
Jan 02, 2019Guru - Experienced User
That works too. You can use that configuration.
IF your don't bridge the FIOS, i would use the FIOS DMZ for the Orbi router if your using it in router mode.
Enjoy. :smileywink:
