sdcycling
Dec 07, 2021Aspirant
Connecting Netgear Orbi RBK50 to Nokia BGW320-505
I am stuck and I need some help. I turned off the 2.4GHz and 5GHz Wi-Fi radios on the BGW320. I enabled IP Passthrough on the BGW320 with DHCPS-Fixed. I manually entered the MAC address of the Orbi RBK50 Router. I changed the LAN IP address on the RBK50 to 192.168.2.1 because I thought that there could be some conflict with the BGW320. The Orbi RBK50 is in router mode. I power-cycled the BGW320 and the RBK50. I can't get the Wi-Fy to work on the RBK50. What am I missing? Thanks for your help.
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/OrbiYour ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you.
Couple of options,
Thank you.
