Cbritchey
Jun 06, 2017Aspirant
Connecting Orbi Router to Ethernet drop vs cable modem/ router
Hi, my home is wired for Ethernet and my Fios router is located in my unfinished basement. I was wondering if I could connect my Orbi router to one of my Ethernet drops in my main living area to provi...
Cbritchey
Jun 07, 2017Aspirant
Thx for the reply. There is currently a switch between the Fios router and the drops. Is that ok or do I need to move off the switch directly to the Fios router?
- rhester72Jun 07, 2017Virtuoso
It will work either way, though you will likely have problems with guest isolation if it isn't in AP mode.
Rodney
