Cbritchey
Jun 06, 2017Aspirant
Connecting Orbi Router to Ethernet drop vs cable modem/ router
Hi, my home is wired for Ethernet and my Fios router is located in my unfinished basement. I was wondering if I could connect my Orbi router to one of my Ethernet drops in my main living area to provi...
Cbritchey
Jun 07, 2017Aspirant
Thx for the reply. There is currently a switch between the Fios router and the drops. Is that ok or do I need to move off the switch directly to the Fios router?
rhester72
Jun 07, 2017Virtuoso
It will work either way, though you will likely have problems with guest isolation if it isn't in AP mode.
Rodney
