chinesebookie
Jan 03, 2018Aspirant
Connecting Orbi to a Fiber GPON optical unit
Newbie question, sorry if it is too basic. I have a Fiber connection to the local phone company. All the Orbi docs say to hook it up to the cable modem for installation. What I have is a box that...
- Jan 03, 2018
chinesebookie wrote:
I've been searching the telco forums and found that it is possible to change connection type from Router to Bridge. is that what you mean?
Yes
If I did that, the Orbi base station would provide DHCP and wifi functions?
Yes
Or I can configure the base station and satellite as access points? Would they extend the existing wifi SSID throughout the house?
Yes and Yes
Physical configuration:
Fiberhome --> Orbi base station --> Orbi satellite-or-
--> Orbi satellite
Fiberhome to Orbi base station via a wired connection? And from either fiberhome or base station to satellite via wireless or wired?
I think the second configuration would only work if the Orbi base station is in AP mode. The first configuration should work in either mode.
TheEther
Jan 03, 2018Guru
You must always have an Orbi base station to go with the satellites. The satellites won't work on their own.
The Fiberhome is a combination ONT and router. You have two choices. Either disable the router in the Fiberhome (I don't know if that's possible). Or put the Orbi into Access Point (AP) Mode. Either way will ensure that you have a single IP subnet (i.e. a flat, simple to manage network where all devices can reach each other).
- chinesebookieJan 03, 2018Aspirant
Or I can configure the base station and satellite as access points? Would they extend the existing wifi SSID throughout the house?Physical configuration:
--> Orbi satellite
- TheEtherJan 03, 2018Guru
Yes
Yes
Yes and Yes
--> Orbi satellite
- JMU1998Jan 03, 2018Luminary
For better results and stability if you put Orbi in AP mode make sure to disable wifi on the router(FiberHome or the one you mentioned) so wifi is only active via Orbi units.
