chinesebookie
Jan 03, 2018Aspirant
Connecting Orbi to a Fiber GPON optical unit
Newbie question, sorry if it is too basic. I have a Fiber connection to the local phone company. All the Orbi docs say to hook it up to the cable modem for installation. What I have is a box that...
- Jan 03, 2018
chinesebookie wrote:
I've been searching the telco forums and found that it is possible to change connection type from Router to Bridge. is that what you mean?
Yes
If I did that, the Orbi base station would provide DHCP and wifi functions?
Yes
Or I can configure the base station and satellite as access points? Would they extend the existing wifi SSID throughout the house?
Yes and Yes
Physical configuration:
Fiberhome --> Orbi base station --> Orbi satellite-or-
--> Orbi satellite
Fiberhome to Orbi base station via a wired connection? And from either fiberhome or base station to satellite via wireless or wired?
I think the second configuration would only work if the Orbi base station is in AP mode. The first configuration should work in either mode.
chinesebookie
-or-
--> Orbi satellite
TheEther
Jan 03, 2018Guru
Yes
Yes
Yes and Yes
--> Orbi satellite
- JMU1998Jan 03, 2018Luminary
For better results and stability if you put Orbi in AP mode make sure to disable wifi on the router(FiberHome or the one you mentioned) so wifi is only active via Orbi units.
- chinesebookieJan 03, 2018Aspirant
Thanks for that tip. How does this help with reliability/performance?
Thanks a lot! This answers almost all of my questions. Now I just have to figure out how to get it in Manila without paying an extra $150 for Amazon shipping and customs. On backorder at B&H, and shipping is much less, though customs is a big question.
