metter
Jan 03, 2017Aspirant
connecting orbi to a switch vs directly to dsl modem?
My current connection: dsl service comes into house directly into a filter, then 2 outs (one to phone service throughout the house and one to dsl modem). my dsl modem is then connected to a 16 port...
- Jan 03, 2017
Yes, and set Orbi to AP Mode. If you miss this during setup, you can change it in the Orbi ADVANCED page in Advanced Setup.
rhester72
Jan 03, 2017Virtuoso
Yes - in AP mode, that's exactly how it works. It doesn't matter if it's connected directly to the modem or a switch off the modem.
Your other option is to switch your modem to bridged mode and use the Orbi as both your router (firewalling, etc.) and your AP.
Rodney
- swrtwdrvJan 03, 2017Apprentice
Right on. Connect 16 port switch to Orbi, and Orbi to modem.
- metterJan 03, 2017Aspirant
Thanks - so can i connect the orbi to the 16 port switch only (no direct connection to the modem - only through switch) just as i do now with the wireless access point? Am I following you correctly?
