  • The Echo/Echo Dot and Echo Show have different processes for connecting to wifi, which Echo device are you trying to connect ?
      • Roamabout's avatar
        Roamabout
        Luminary
        So the echo dot gets configured via the alexa app on your phone/tablet.
        You put the dot into config mode, connect to it over wifi with your phone/tablet and then go through the steps to connect it to the Orbi.
        What part of that process is not working ?
