Slosh104
Mar 04, 2018Aspirant
Connecting Orbi to Alexa
Alexa will not discover my Orbi. How can I get Alexa is integration with Orbi?
- RoamaboutLuminary
The Echo/Echo Dot and Echo Show have different processes for connecting to wifi, which Echo device are you trying to connect ?
- Slosh104Aspirant
I have the Echo Dot.
- RoamaboutLuminary
So the echo dot gets configured via the alexa app on your phone/tablet.
You put the dot into config mode, connect to it over wifi with your phone/tablet and then go through the steps to connect it to the Orbi.
What part of that process is not working ?
