victor_luquis's avatar
Oct 11, 2018
Connecting PS4
I just purchased my Orbi and everything is connecting to the internet but my PS4 how do I connect it I’ve been searching and have tried serval things but none of them have worked
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    How are you tryng to connect the PS to the Orbi? Wireless or wired? Try both?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What security modes are you using on the Orbi? WPA2 and AES only?
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Enable Daisy chain if you updated to v210 FW...
