colslick
Sep 03, 2018Aspirant
Connecting RBK 50 to gateway
I have an xfinity Technicolor 3941T gateway which I want to keep at least until I'm sure the RBK 50 will solve my dead zone problems. I'm not to tech savy and want to set the Orbi up with the best ch...
Sep 04, 2018Guru - Experienced User
Yes you need to disable the wifi on the ISP modem/router. Having other wifi too close will cause problems. You want to use the Orbi as the main wifi and nothing else.
