Ozmeister2019
Aug 02, 2020Tutor
Connecting RBR50 to the new LBR20 4G router.
Hi I am currently running a RBR50 and RBS50 with wired backhaul. The RBR50 is connected to a HUAWEI 4G router that I am running in bridge mode to provide my internet access. The Huawei is in the top o...
Aug 02, 2020Guru - Experienced User
The RBR and LBR would be separate wifi systems. You could possibly connect the RBK to the LBR and configure the RBK for AP node using separate SSID names.
webwude
Aug 23, 2020Aspirant
I have almost the same situation: Huawei LTE Router with DMZ, Orbi RBR50 and 3 satellites RBS50.
What would the options to combine this with an LBR20? Could the RBR50 act like another satellite?
Any ideas?
Any ideas?
- Ozmeister2019Aug 23, 2020TutorThe conclusion I came to is you can’t use the RBR50 as there is no option to run it in “satellite” mode so you cannot have true mesh setup combining it with the LTE router. There are articles around changing the firmware on the RBR50 to effectively make it a RBS50 but this sounds risky and I don’t have the time to mess around with it. I believe the only official supported thing is to replace the RBR50 with and another RBS50, but given how much I have already spent on this kit, and the cost of adding another RBS50 it’s not something I am going to rush out and do.
