phydauxs
Jul 24, 2025Tutor
Connecting Security Cameras to Wifi Network
I recently had to reset my Orbi router (RBR50). After I did that, I couldn't connect my Reolink security cameras to my main WIFI network (even though they were connected before the reset). However, t...
CrimpOn
Jul 24, 2025Guru - Experienced User
phydauxs wrote:recently had to reset my Orbi router (RBR50)
After the reset, the Orbi system was configured with exactly the same WiFi credentials as before? (SSID/password)
Every WiFi device except these cameras connected correctly?
My RBR50 system has a number of Reolink cameras connected to the primary WiFi network with "no problems". (have been for YEARS). (have never enabled Armor, so have no idea what effect that might have).
- phydauxsJul 25, 2025Tutor
Thank you for your reply. Yes, Orbi system was configured with exactly the same WiFi credentials as before? (SSID/password). I have many other wifi devices and they all reconnected after the reset. Any other thoughts?
