phydauxs
Jul 24, 2025Tutor
Connecting Security Cameras to Wifi Network
I recently had to reset my Orbi router (RBR50). After I did that, I couldn't connect my Reolink security cameras to my main WIFI network (even though they were connected before the reset). However, t...
CrimpOn
Jul 24, 2025Guru - Experienced User
phydauxs wrote:recently had to reset my Orbi router (RBR50)
After the reset, the Orbi system was configured with exactly the same WiFi credentials as before? (SSID/password)
Every WiFi device except these cameras connected correctly?
My RBR50 system has a number of Reolink cameras connected to the primary WiFi network with "no problems". (have been for YEARS). (have never enabled Armor, so have no idea what effect that might have).
phydauxs
Jul 25, 2025Tutor
Thank you for your reply. Yes, Orbi system was configured with exactly the same WiFi credentials as before? (SSID/password). I have many other wifi devices and they all reconnected after the reset. Any other thoughts?
