phydauxs
Jul 24, 2025Tutor
Connecting Security Cameras to Wifi Network
I recently had to reset my Orbi router (RBR50). After I did that, I couldn't connect my Reolink security cameras to my main WIFI network (even though they were connected before the reset). However, t...
gramwilliam
Jul 29, 2025Aspirant
Power on camera use app to select WiFi enter password done.
phydauxs
Jul 29, 2025Tutor
Thank you for your reply. Unfortunately that is the part that isn't working. It can connect (every time) to my guest network but not the main network.
