MSRadell
Jan 10, 2018Aspirant
Connecting to a external VPN
Connecting to an External VPN I need to connect to an external VPN to download files at various times. This used to be no problem with my previous Netgear router but now that I'm using an Orbi I ...
st_shaw
Jan 11, 2018Master
If you have searched the Internet for information on this issue, you will have learned by now that the Pace cannot be made to pass-through VPN. You will need to replace it with another gateway. The Motorola NVG589 reportedly works fine. It's possible that switching to openvpn might work with the Pace, but that's just a guess.
Try searching on "pace dmz-plus vpn"
This thread is one example:
