Tobold
Mar 30, 2020Aspirant
Connecting to an Orbi RBR50 when internet isn't working
I have an Orbi RBR50 system which used to work perfectly fine, until the modem provided my my ISP broke down and was replaced by a new model. Now the new modem (a b-box v3+) and the Orbi RBR50 seem to have some incompatibility, and the modem doesn't assign an IP address to the Orbi. So the Orbi doesn't have internet access, and when I use the Orbi app, the app gets stuck and tells me that there is no ethernet cable connected to the Orbi (of course there is).
Now I would like to use orbilogin.com to change settings on my Orbi and maybe fix the problem. However, when I connect to the Wifi of the Orbi via my iPad, the Wifi shows up as "no internet connection". And because of that, using a browser to connect to the Orbi via orbilogin.com doesn't work (Error message: "Safari cannot open the page "http://orbilogin.com/" because your iPad is not connected to the internet. And as I already said, the Orbi app doesn't work either.
I tried to connect the Orbi with an ethernet cable to a PC laptop. But when I surf to orbilogin.com, it tells me that I am not on an Orbi Wifi.
So how am I supposed to change the settings on my Orbi?
Power OFF The ISP Modem for 30 seconds then back ON. Press the reset button in back of the RBR for 15 seconds then release. Connect a wired PC to the back of the RBR and using a web browser walk thru the setup wizard at 192.168.1.1 or orbilogin.com.
Does the modem have a built in router already? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- ToboldAspirant
#FURRYe38 Thank you for the tips.
I spent a whole day already following different variations of the modem reboot / Orbi reboot sequence. Nothing helped.
Yes, the modem has a built in router already. And very few accessible settings, seems to be kind of hardwired by the ISP. I'll try the AP mode on the Orbi once I manage to connect to it.
Connecting to 192.168.1.1 gets me to the settings of my modem, not the Orbi. Orbilogin.com doesn't appear to be working either. I think somewhere in the process the internal IP address of the Orbi automatically changed, but I don't know to what exactly. I think it started with a 10.
I would do this, disconnect the RBR from the modem. While having a wired PC connect to the RBR. Configure the RBR here for AP mode.
One you have the RBR set up for AP mode, then connect it back to the modem.
Sounds like the modem is working with 192.168.1.1 while the RBR also works at this same IP addresss by default however it should auto change to something different, i.e. 10.something.
I would contact your ISP and have them disable any and all wifi radios on the isp modem if they are enabled.
