petermariana's avatar
petermariana
Connecting to internet
Bought this today but although I can connect my devices - phones and computers - to Orbi router, the router will not connect to the internet.
My old router works just fine - so no issue with the modem. Only possible problems are (1) my modem is not compatible with the Orbi (hard to believe as its a recent NBN issue) and (2) the orbi is broken.
Help much appreciated. Peter
    • petermariana's avatar
      petermariana
      Thanks for your help.
      The modem is NBN provided ARRIS CMB200.
      I'm sorry I don't know the router firmware version. Router is RBR 50 v2. I don;t have a double NAT setup.
      Regards
      • FURRYe38's avatar
        Power OFF the isp modem for 30 seconds then back ON. Right after you turn ON the modem, factory reset the RBR and walk thru the setup wizard nd setup the RBR from scratch. Don't enable Circle or Armor.
        What FW version are you using?
        Swap out LAN cables between the RBR and modem. CAT6 is recommended.
        Have the ISP check the signal and line quality UP to the modem.
        Be sure there are not coax cable line splitters in the between the modem and ISP service box.
        Be sure your using good quality RG6 coax cable up to the modem.
        Regards
