HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Apr 17, 2018Guru - Experienced User
HighDesert
Apr 17, 2018Tutor
Speed test witking on my iPhone now. Thx for fixing
- FURRYe38Apr 17, 2018Guru - Experienced User
Glad it's working now. Enjoy.
- GuanadusApr 17, 2018TutorI have tested the speed test in my iPhone and works again.
On orbilogin working too
It seems the problem has been fixed
Thanks- PaulK617Apr 21, 2018StarNow my problem just got worse. Speedtest is fixed but losing connection on my Nest thermostat, then garage opener, now Nest thermostat went offline again. Three times in 3 days. I’ve rebooted the router for a temporary fix. I have about 20 devices. This is even more frustrating. I could live with using Speedtest outside of Orbi. Anyone else have this issue after Speedtest fix?
