ChuckGallagher
May 22, 2018Aspirant
Connection help
I'm a novice! Connected the RBK50 but cannot seem to get the Add-on Satellite to connect. Any suggestions. Keep doing what the vids show and it just won't connect. I'm lost.
- May 22, 2018
How far appart is the satellite from the router? Should be starting at 30 feet.
Are you first pressing the sync button on the router, then press the sync button ON the satellite after you see the slow pulsating white LED on top?
Try factory reset the satellite. It will blink ON and OFF, then begin to pulsate slowly like it's breathing. When this happens, press the sync button on the router, then press the sync button ON the satellite. It should turn BLUE on top after a minute or 2. Give it 5 minutes if needed.
May 22, 2018Guru - Experienced User
- ChuckGallagherMay 22, 2018Aspirant
Thank you and I will gladly give this a try.
