janhillebrand
Sep 15, 2022Tutor
Connection issues with a single device
Hi,
I recently bought the AX4200 5G router on firmware v4.6.5.11_1.5.50 and one satellite running v4.6.5.14, which should be the latest available versions respectively to my knowledge. There are approx. 10 devices in my network, including TVs, smart phones, a PS5 and laptops. In general, I'm enjoying fast connection speed without any issues on all devices.
However, my MacBook Pro (16", 2021) keeps running into connection issues, although they are not constant. When the issues occur, it connects to the wifi and also gets an IP address without any problems, but doesn't have internet access. I cannot connect to the router's web interface from the laptop by entering its IP in the browser either. Nevertheless, I can stream 4K movies on any of my other devices at the same time, so there definitely is an internet connection and the DHCP, etc. seem to work fine for the other devices. Also, when I disconnect my MacBook from the router and hotspot it through a phone, I instantly get a flawless connection. Furthermore, I don't have this kind of issue with my laptop on any other wifi that I frequently hook up to, e.g. at the office, restaurants, etc. The laptop's located approx. 1.5 metres from the router.
I have already tried different solutions without success, including:
- Restarting the laptop
- Deleting the wifi profile from the laptop's network list and re-connecting
- Restarting the router and the satellite
- Moving the laptop to different locations in the house
I have been using the computer the past approx. two weeks without incidents, including for data-heavy videoconferencing, downloading hundreds of GB of data, etc. Then, suddenly, it doesn't connect from one minute to the other. I was on a video call and as I hopped off to join another, I couldn't. So, I wasn't meddling with the settings or changing anything on the laptop itself.
A few additional notes:
- I used the Terminal on my MacBook and on a phone to ping different devices on the network, with the phone directly next to the laptop. From the laptop, when pinging the router, the phone, or the PS5, approx. a third of packages were timed out. When pining from the phone, on the other hand, I got stable and fast pings from the router and the PS5 but not the laptop. Pinging the MacBook from the phone, it would take up to 17s for a single ping, albeit no packages were lost or timed out. You can see the laptop and the phone pinging the router, respectively, in the PDF attached (page 1 laptop, page 2 phone).
- On the PS5, I do infrequently get a message telling me that wifi connection is lost. I'm unsure why this is, and it certainly is annoying, but because it restores instantly without me taking any further action, I've seen it as a minor nuisance so far. Potentially, it could be related.
The first time I faced this issue and it persisted for several hours, the only way I managed to fix this issue was by re-installing the router from scratch. This was about two weeks ago and afterwards, everything worked well. But now the issue has returned and I can't seem to be able to fix it. Of course, I don't see myself re-installing the router every two weeks.
Any advice? Any further tests I could run? This is very frustrating, as I am working more than 50% from my home office and investing into this 5G router was supposed to replace the more expensive fibre optics connection. Otherwise, I could've bought a router 25% of the price. I'm certain the 5G connection in my area isn't the issue, since all other devices work without problems and delays at the exact same time the laptop doesn't (plus, monitoring the speed over several weeks, on average the downlink's consistently above 300 Mbit/s). Thanks in advance!
So what model modem do you have? Is this a Orbi NBK750 series?
If you turn OFF the RBS, does the Mac Book still exhibit problems?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What OSX is on the Mac Book? I use Monterey and Ventura on my Mac Book Pro 2018.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Hi,
I appreciate your feedback. The router itself is the modem, since it is a 5G router, hence no cable necessary. I'm on MacOs Monterey 12.6. I'm not sure how the size of my apartment matters if the router is 1.5m/5 ft away from my laptop with no walls or other obstructions in between. At any rate, the satellite is about 10m/30ft away from the router. All the other devices, both those connected to the satellite and router, have very good connection speed, independently of their location. Any further ideas? Thanks.
Cheers,
Jan
