subha_m
Jan 01, 2019Follower
connection not private error in chrome
Hi,
Ever since I installed the ORBI wifi, certain sites on chrome give me a "your connection is not prvate" error. I have checked the system time and date and they are correct. Has anyone else enco...
JoeCymru
Jan 01, 2019Virtuoso
The most common occurrence is going to sites with expired SSL certificates.
Just some suggestions:
First check your anti virus program treatment of SSL certificates. You should be able to liberalize this.
Next go to the Chrome tag settings below.
chrome://flags/#enable-mark-http-as
That should be in the default, which is a neutral setting.
Next go to this community thread and try this fix.
https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125
