- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Blocking Websites - Solved
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI is blocking HTTPS websites that are not explicitly defined in URL.
To unblock any https website, do the following:
Log into to your router admin console (https://orbilogin.net)
Click on Advanced Tab
Click on Security >> Block Services
Click Add
Click on Service Type DropDown and Select HTTPS
Click Add to save
Your all set. Close out admin and then retry ORBI admin console as just orbilogin.net and waalaa.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Blocking Websites - Solved
Hi jeffbr26
Thanks for sharing these tips on what is working for you.
Blanca
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks. I'll give that a go now. Orbilogin was of course one of the sites I couldn't get to! Hope this works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
all working fine now. thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. This fixed the same problem I was having as well!
It begs the question why by default are these routers set to block HTTPS sites which are not defined in the URL? I'd imagine heaps of people will be puzzled running into this issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Combo Units:
Couple of options to try,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
My Setup (Cable 900Mb/50Mb)CM1100>XR450> > EX7700 (Wireless Extender)
Additional NG HW: Orbi CBK40(Gateway Mode), R7800, EX7500/EX7700 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im having the same issue, how did you end up logging into Orbilogin ? It keeps blocking me! Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
@joewerms , looks like you have double routers in your network and that's why you can't login to Orbi, and this is -probably- the reason of seeing some sites blocked.
Please open a Command Prompt on any computer attached to Orbi (the comupter you're trying to login to Orbi from) and type:
> tracert 8.8.8.8 (traceroute to Google’s DNS server)
If you see two private IP addresses listed in the first two hops then you have double NAT and you need to modify your setup. If you see only one private address and the second hop shows a public address, then you’re all good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How were you able to get logged in to orbilogin.net?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Were you able to figure out how to log in to orbilogin.net? I can't get to log in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What browser are you using?
Do you have a wire connected PC or laptop with a web browser navigating to orbilogin.com or 192.168.1.1?
- Mark as New
- Bookmark
- Subscribe
- Permalink
this fixed my apple tv's, and my email links
- Mark as New
- Bookmark
- Subscribe
- Permalink
What did you do to fix your problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
First, thank you for the original post. The quick start guide that came with my router said I am supposed to go to orbilogin.com, not net, so I could not get in until I figured out the IP address.
I followed the instructions and whitelisted HTTPS, but I am still being told that sites like Facebook are insecure. I also have services blocking set to never.
I have the Orbi connected via LAN to my AT&T Arris BGW210-700 gateway. The gateway is set to Passthrough mode with DHCPS fixed to the Orbi's MAC address. My computer is connected to the Orbi via LAN. I just installed the Orbi yesterday, and that is when I started having problems with sites being blocked. I have also had some apps on my phone blocked. I am assuming the issue has to be in the Orbi, because none of these problems happened before. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try putting the modem back to modem/router mode and configure the Orbi for AP mode and see if sites are blocked?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the most up to date firmware. Since I wrote the post, I also discovered that my Ring doorbell would not connect. I put it in AP mode like you suggested, and now everything works great! I'm not sure it is worth trying to play with the Orbi as a router if it is working so well as an AP. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
AP mode on orbi is only needed if you have a main host router up stream from the RBR and it can't be either remove or bridged. Some cases the main host routers DMZ can be used for the Orbi to allow it to be used in router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having trouble getting to https://orbilogin.net/ too - it's being blocked because of this issue. Any hints on how to get to the settings so I can access the advanced settings and make this change?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
Are you trying to access the RBRs web page with a PC and web browser?
@acemathias wrote:I'm having trouble getting to https://orbilogin.net/ too - it's being blocked because of this issue. Any hints on how to get to the settings so I can access the advanced settings and make this change?
