Asdirect
Aug 10, 2017Guide
Connection protocol 2.4 g vs 5 g -what is the deal??? Orbi-AC2200
I just don't understand the logic in which the mesh network uses.
i know there are a few threads on 2.4/5g, but I want to give my specific issue.
i have an RBR40 and RBS40
I have the main router downstairs in my office and the satellite upstairs in my bedroom.
My my main problem is with my new (LG) OLED TV. This TV supports a 5g connection, because that's how I connected on my last router, yet I can't get a 5g connection with the Orbi.
The tv is 2 feet away from the satellite and most of the time it doesn't even connect to the satellite, it connects at 2.4 to the router downstairs. The satellite phiscally is sitting between the tv and the router.
Now i I know the satellite is working, because I have about 5 other devices connecting using both bands.
Why hey would my TV) skip the satellite and connect to the further away router at a slow speed????
Any words of wisdom would be greatly appreciated.
AD
- st_shawMaster
The best solution is to connect your TV with an Ethernet cable and save the wireless airspace for your other devices.
If your TV doesn't have an Ethernet port, then you could try moving the Orbi farther away from the TV. Two feet might be too close.
- AsdirectGuide
Thanks for the reply. Im not going to connect a wire out of shere principal :) :smileyhappy:
i will ill try to move the router. This band steering really is offel.
wireless AC is very sensitive , your sat could be just too close to the tv and causing issue , move it further away
