Nrk's avatar
Nrk
Connection timed out banking websites
On odd occasions I am not able to connect to these websites. ( Connection times out).
https://netbanking.hdfcbank.com/netbanking/
Onlinesbi.com
I have power of and power on the router twice or thrice before these sites become accessible.
I can access these sites through my mobile and through VPN.
Any thoughts
  • Nrk's avatar
    Nrk
    Jun 20, 2019
    Ok doesn't seem to be a problem with the Orbi ... multiple people using the same ISP are facing the problem..
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Only this site or do others do the same thing?
    Onlinesbi.com
    Any thoughts
    • Nrk's avatar
      Nrk
      Orbi acts as a router.
      Firmware Ver 2.3.1.58
      The cable from ISP connects directly to Orbi there is no modem on premises.
      • Nrk's avatar
        Nrk
        These are the only sites where I have noticed the problem.
