EtVous
Oct 08, 2017Aspirant
Connectivity Issues. Orbi65 with Xfinity Modem Router combo. Bridge or Access point or?
I have an Xfinity Modem / (Dual Band) Router Combo. I used to use a Netgear Nighthawk X6 router (with the Xfinity combo unit) that our family was very happy with! Lots of computers, phones, tab...
- Oct 08, 2017
Will I need a second satellite in the house because the Orbi router itself doesn't have much coverage for my house or because it by itself may no longer reach as far as the satellite in the garage?
Could be both. However, I would try with what you have first, because it might work. Logically, if you were using the Orbi router and another AP to cover inside the house before, and you turn off the other AP, you might need a satellite in the house for complete coverage. The other issue is if the new firmware gives you reduced range from sat-router. If that happens, you could possibly shorten the distance by putting that second satellite in between the router and existing satellite in the garage.
Also, is the daisy chain capability something that I need to manually set up or will it do it automatically when I add the extra satellite?The daisy-chain mode can be selected in the router GUI. It was enabled by default on my system. I only have one sat though, so I've never tried to daisy-chain.
EtVous
Thank you so much for the quick and helpful reply. It makes sense. I just have a couple of follow-up questions.
Will I need a second satellite in the house because the Orbi router itself doesn't have much coverage for my house or because it by itself may no longer reach as far as the satellite in the garage? Also, is the daisy chain capability something that I need to manually set up or will it do it automatically when I add the extra satellite?
Thank you again!!
st_shaw
Oct 08, 2017Master
