dwolfenbarger
Apr 01, 2017Guide
Connectivity loss when switching back to the router from satellite
Wonedring if anyone else is seeing an issue similar to the below. At this point I've replaced the Orbi router, had a spare, with no success in correcting the problem. The Orbi is running in AP mode d...
- Apr 12, 2017
In the event anyone comes across this thread with a similar issue... bad hardware. Netgear agreed to do an RMA of the satellite unit and it arrived earlier this week. After replacing the old unit everything is working as expected.
dwolfenbarger
Apr 05, 2017Guide
Contacted support today and downgraded the firmware and removed a device from the switch and connected it directly to satellite #1. I was hopeful the issue might go away but same issue with the directly attached device. Waiting on a response but I'll update this thread when I know more.
dwolfenbarger
Apr 12, 2017Guide
