Kbomb20
Nov 25, 2018Aspirant
Constant lag spikes while gaming on PS4
Hello. I just bought the Orbi RBK50 system and configured it in my house. Everything looks great and I am getting 200-300mb in my basement where I have my satellite. I tried gaming on my PS4 through m...
Nov 26, 2018Guru - Experienced User
What FW is currently loaded?
Connect the PS via wired LAN cable. Do you see same problem?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- Kbomb20Nov 26, 2018Aspirant
Firmware: V2.2.1.210
Modem: Arris TM1602
ISP: Charter/Specturm 400MB
I have not see the same problem with my router
My house is 1999 sqft
The satellite is in my finished basement while the base unit is on the first floor. They are only about 15-20ft away
Channel: 2.4Ghz is Auto and 5Ghz is 48
I can see about 5 other wifi signals
My router was was new so I do not know what the FW was before I upgraded it.
I am currently testing out Port Forwarding on my PS4 hoping it will fix the issue as well/
- Kbomb20Nov 26, 2018AspirantThis is day two using the router and I’ve seen slight quick pauses in streaming PlayStation Vue on my Amazon Fire TV. My Fire TV is about 5 feet away from my base unit.
I also noticed that I couldn’t hard reset my router yesterday when testing other changes - FURRYe38Nov 26, 2018Guru - Experienced User
Modem: Arris TM1602
This is too close. 30 feet is recommended in between them to begin with depending upon building materials.
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
I believe my Daisy Chain was enabled by default once I upgraded. I have most of these others disabled already but I will make sure and test.
