feebthompson's avatar
feebthompson
Constant WIFI issues with ORBI RBR50
I purchased the Orbi system as we were having issues with WIFI strength in our home and possibly too many devices connected. We have 1 satelite. I have no issues when using ethernet however when using phones or smart TVs the speed is awful and often the connection displays as "no internet". Netflix will buffer every few minutes and then sometimes we will get booted out of the app altogether. Im not very tech savvy so need solutions in simple terms. Sped tests always display as very good. Help
1 Reply
  • FURRYe38's avatar
