njkid3's avatar
njkid3
Tutor
May 11, 2017
Content loading issues over WiFi for Orbi RBR50
Details of devices connected to Orbi: Netgear CM1000 modem supplying the connection Desktop PC hardwired running Windows 10 most recent update Macbook Air (Mid 2013) running latest MacOS Chromec...
  • njkid3's avatar
    njkid3
    May 15, 2017
    DarrenM,
    I never removed them just in case the router didn't work. I changed the SSID to a completely different one. I have been meaning to post an update to this post but I couldn't find the edit button. After spending time with customer support and going through the motions, it seemed that I had a bad firmware update. I did an additional factory reset and then reconfigured the router. This seemed to fix the issue. So a lesson learned is that there exists an intermittent issue with the Orbi where a firmware update does not fully replace the old firmware and creates issues. That last sentence is my deduction of the issues and eventual solution. Maybe a firmware update to address this possible issue is needed in the future?
