Oliverpool
Sep 19, 2017Guide
Continual internet/satellite/router disconnect
Has everyone given up on orbi? I have TWo rbk50 sets and they both give me disconnect issues. Slow connectivity and basically useless. Worse then my single router previously. They are in Totally diff...
Oliverpool
Sep 19, 2017Guide
One is in ap mode the other is in router mode. I believe the router mode one is still on the latest v1.12 firmware.
martyfp
Sep 19, 2017Luminary
I use router mode with the latest v2.0.xx firmware which you can download from here :
https://community.netgear.com/t5/Orbi/OrbiOS-2-0-availability/m-p/1368730#M13446
It fixed many users issues with stability so certainly worth a shot.
- JenningsjsSep 19, 2017AspirantI also meant to ask, did you ensure wireless was turned off on the original cable modem? Sometimes the dual signal can cause issues.
- OliverpoolSep 20, 2017Guide
Yes. For the AP mode, there are no other wireless router switched on other then my neighbours....
