  • FURRYe38's avatar
    Converting RBR to RBS isn't supported. You might do a search on reddit for this info on there as I had seen it on there. I would not recommend it unless you are skilled and have the experience to do this. Bricking your expensive RBR is possible.
    Good Luck.
    • madhatter's avatar
      madhatter
      Apprentice
      yes, I know it's not supported, and the RBR is useless as it is since I am using an Orbi RBR50 as a router.  I did check reddit and the instructions there were for an RBR50 > RBS50 conversion.
      Thanks!
      • FURRYe38's avatar
        I can only presume it may apply to the RBR40. Again, it's a risk. Up to you.
        Good Luck.
