Sunray20's avatar
Sunray20
Correct Adaptor for Orbi AC2200 (RBR40)
Hi, I hope this is not too stupid a question but my adaptors have failed on two of my three orbi routers. I bought it in the U.S. and using in the UK so a voltage issue could be the reason but this has not happened on any other U.S. product I use. Is there a correct adpator I can buy in UK for this product? Thanks.
  • FURRYe38's avatar
    Adatpers here for the RBR50 v1 I have is rated at 100-240v 50/60Hz Output to 12v.3.5Amp
    These should work in your region.
    Something to contact NG support and ask them if there is a more specific UK version of adapter that will work.
