ableman42
Feb 28, 2019Guide
Cutting Verizon out of the equation! Orbi mesh
Looking to fully cut the cord. I use Rokus and Sling. Have the RBK50 mesh, love it. Currently using Verizon Fios for basic TV and internet. Want to cut down Fios services to just internet. Two questi...
petieg1
Mar 01, 2019Aspirant
I made RBR50 my main router, just release DHCP IP address from Verizon router first, then Orbi should pick it up when you plug the cat5 into WAN/Internet port. My Verizon router had coax and Ethernet active. I've found that the TV boxes use the coax connection for their Internet -- thus, if you have TV you will have no guide info if you remove Verizon router. After some trial and error, i put my Verizon box on a different subnet, and made it think my LAN connection to the Orbi was 'the Internet' and it worked fine. I don't want to relive this scenario again. I got excited for the Verizon One wireless TV box, but it seems that you need more than one TV box - the main one is still wired, any add'l ones can be wireless. We only have one so i figure out the above to get TV Guide info.
Amazing, because the cable boxes even have an Ethernet port, it's just that Verizon doesn't activate them. Ugh...
- Melvinoa82Mar 11, 2019AspirantHow where you able to get the TV guide info?
