SpikeB's avatar
SpikeB
Initiate
Oct 07, 2018
Daikin Wifi
I am trying to connect a Daikin WLAN adapter through my Orbi mesh but for some reason my Orbi is not being found. Seeing as all of my neighbour's WiFi routers show up, I guess the error is somewhere in my Orbi set up.
Any ideas.
  • SpikeB's avatar
    SpikeB
    Oct 14, 2018
    Brilliant, thank you very much, got there in the end.
    I'd already tried using Channel 11 but with no joy so I thought it was something else. I don't know if that's peculiar to my set up though because I moved out to 6 and it's working perfectly.
    Thanks again.
  • FURRYe38's avatar
    What FW is currently loaded?
    Do other devices connect to the Orbi? If so, then this particular adapter maybe the problem.
    Try this, Temporarily disable WPA security settings on the Orbi then try to see if the adapter sees and connects to the Orbi. If so, try setting WPA and TPIK and test. Then try WPA2 and AES only.
    Ensure the adapters drivers are up to date.
    • Blanca_O's avatar
      Blanca_O
      NETGEAR Employee Retired
      SpikeB
      We’d greatly appreciate hearing your feedback letting us know if the information FURRYe38 provided has helped resolve your issue or if you need further assistance.
      Blanca
      Community Team
      • Blanca_O's avatar
        Blanca_O
        SpikeB
        Thank you for the update. Glad to know that it's working now.
        Blanca
        Community Team
    • SpikeB's avatar
      SpikeB
      Initiate
      Thanks again.
