SRNIJMU
May 26, 2020Aspirant
Daily Reboot Required
My Orbi was working fine for a year until about two weeks ago and now requires daily reboots. The network connection drops. After rebooting, everything is fine for about a day. Some days, two reboots are required. Firmware 2.5.1.8. This convienently happened just after the warranty ran out.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Has a factory reset and setup from scratch been performed since last FW update?- SRNIJMUAspirant
Thank you. Will answer to the best of my ability below the questions:
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
>Comcast XB6 xFi Advanced Gateway Modem TG3482G (ARRIS)
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router> Distance is less than 30 feet. It's a total loss. Computers connected directs to the router by less than 10 feet lose signal line-of sight also.
Any Wifi Neighbors near by? If so, how many?>Channels are Auto. Maybe pick up one wifi neighbor weakly nearby. With your suggestions here and below, is there an order in which you recommend trying them? Why would this be required after a year of good function?
>See about about question regarding order of fix attempts.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).>See about about question regarding order of fix attempts.
Has a factory reset and setup from scratch been performed since last FW update?>No - would this help?
What mode is the Arris modem working in? Bridge mode is recommended since this model has a built in router and wifi already. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopRBS should be 30 feet to start or farther. Any closer can cause problems.
Try any of the suggested channels. Due to conditions, neighbor changes and new neighbors may have install there own wifi, this could cause interferences over the years.
"See about about question regarding order of fix attempts." Huh?
I would factory reset first then use the suggestions after you walk thru the setup wizard...pending on modem mode operation confirmation first.
