Chuck_M
Dec 17, 2018Mentor
DaisyChain Setting
I have read with great interest these forums which are very helpful.
A thread or two in here talks to the correct setting for the Daisychain option... but I remain skeptacle/confused on how min...
- Dec 17, 2018
I've lost the posts however others have said here in the forums that with v210, for some reason the features seems to be working differently. I'll try and find it again...
Checked.
Unchecked
Unchecked when wired back haul connected.
Dec 17, 2018Guru - Experienced User
From what I gather, the option should be UN-checked if your using v210. Checked means disabled.
- Chuck_MDec 17, 2018Mentor
Checked means disabled? Awesome & interesting! Has that been verified or just tribal knowledge?
Now the remainder of the questions to be answered are:
- If sattelites are connected in SERIAL to the router, is that checked or unchecked?
- If sattelites are connected in PARALLEL to the router, is that checked or unchecked?
- Does it matter if they are Wired or wireless back to router?
Thanks for the help in advance.
- FURRYe38Dec 17, 2018Guru - Experienced User
Checked.
Unchecked
And final question (for now!)
Since the "Checking" is reversed, is it also reversed on the other settings on that screen (e.g. beamforming etc)?
