rckingsley
Nov 18, 2025Aspirant
Deleting an IP Reservation Not Working
I have an RBR50 (base) and RBS50 (satellite) router setup. They are connected via Coax cable using MoCA, and seem to work fine. A few years ago I reserved some IP addresses, and (not surprisingl...
- Nov 21, 2025
Sorry, everyone. What was actually happening was as soon as the screen popped up to allow me to manually enter another reserved IP, “in the background” was displayed all of the devices that were currently attached to the network (making it easy for me to pick one and reserve it) - “not” the older entries that I thought weren’t being removed.
The user manual didn’t indicate what would happen, and all I saw was the same kind of information without looking at it more closely. My bad…
Thanks for all of the responses with assistance. Very much appreciated.
CrimpOn
Nov 18, 2025Guru - Experienced User
There is only one LAN Setup table, on the router (RBR50).
Could you post a screen capture (similar to this one) that shows the device name?
(to me, "left" refers to the part of the screen where Orbi appears.)
After making changes to the LAN Setup table, you DO click the Apply box at the top of the page?
Which version of firmware is on this system?
- rckingsleyNov 21, 2025Aspirant
