FWIW
Mar 16, 2018Aspirant
Design help
I am building a 2,000 sqft ranch style house with a 1,600 sqft workshop. The workshop is about 100 feet away from the house. I want one mesh network to serve both. I'm thinking of getting the RB53 and placing the base unit at one end of the house, a satellite at the other end, then putting the 3rd satellite in the center of the workshop. I'd connect the workshop unit to the base with Cat-6 cable using the backhaul feature.
does this make sense? Is there a better way?
100ft distance is a bit far away to have an Mesh system to provide between each building that far away. Would be probloematic when wireless. You would be best served by having a main host router or the main orbi system with 1 satellite at the main builting, you may not even need a Satelilite here. Then run a CAT6 LAN cable buried out to the work shop building and place a wireless AP device there.
FWIWwrote:I am building a 2,000 sqft ranch style house with a 1,600 sqft workshop. The workshop is about 100 feet away from the house. I want one mesh network to serve both. I'm thinking of getting the RB53 and placing the base unit at one end of the house, a satellite at the other end, then putting the 3rd satellite in the center of the workshop. I'd connect the workshop unit to the base with Cat-6 cable using the backhaul feature.
Not everyone has problems with the Orbi system.
- Brain29Apprentice
I would strongly stay way from orbi since you will rely a backhaul connection (something that hasn't worked correclty for 2 months so it has been pulled from the auto update)
- AmitRNETGEAR Employee Retired
Have you considered the Outdoor Orbi? RBS50Y
The benefit of it, over an indoor unit, is that you can mount it outside, so it doesn't have to punch through an exterior wall to get to the distance, and it'll be weather resistant. Our internal testing shows that you can easily get multiple 10s of Mbps at that distance in a line of sight testing.
Best case scenario is the RBR50 can be positioned near a window or edge and the RBS50Y be put in the workshop. Worst case, you use to RBS50Y, but that might get pricey.
- FWIWAspirant
I'm not very smart about this stuff and it gives me a headache! :)
So if I understand you correctly, I'd put the base unit at one end of the house near a window, a satellite at the other end, then putting the RBS50Y on the outside wall of the workshop facing the house?
Do you offer a design service?
I'd put the Outdoor Orbi on the outside wall of the workshop, and the other Orbi (not sure if that's Router or Satellite) somewhere in the house, as close to the workshop as you can, preferably in a window. To take full advantage of the speeds, you should get a RBK50 or 53 kit, not the lower spec ones.
- FWIWAspirant
Thanks! Sounds like a good solution.
- FWIWAspirant
also, is it a good business practice to do a wired backhaul the satellite in the house?
