peachfuzz123's avatar
peachfuzz123
Desktop iMAC keeps losing wifi connection with Orbi RBS20
Works fine for several hours and then iMAC loses wifi connection with Orbi and tries to connect with nearby iPhone.  And then I struggle to reconnect to Orbi.
  • CrimpOn's avatar
    CrimpOn
    Is the nearby iPhone operating a WiFi Hot Spot?
    (I turn on a Hot Sport for specific needs or testing, but do not leave it on all the time.  Just curious.)
      • CrimpOn's avatar
        CrimpOn
        Sounds to me like the Mac decided the Hot Spot has a stronger signal and switches. That's what devices do.
        In other words, not "loses connection", but "decides to change".
        I would turn off the Hot Spot and quit burning through LTE data on the iPhone.
