bramsche's avatar
bramsche
Follower
Jan 13, 2018
Detecting Ethernet Connections
Hello.
So I have the RBR50 and the Sattelite and they work great.  However, I noticed when I connect my iMac via Ethernet, it longer shows up under the Device list.  Furthermore, when I go into the sattelite's IP address, it doesn't show up under Connected Devices either.
Is there something I am missing or is the device list to manage wireless devices only?  Thanks.
1 Reply
  • There have been bugs with the recent version UI and the connected device list. If your iMac is working OK when directly connected, then I wouldn't worry about what the connected device list displays in the UI. Hopefully, the next software update fixes it.
