Retired_Member
Apr 09, 2017Device can't connect to main network but can to guest network?
Recently changed my router from an Apple Airport over to Netgear Orbi. Overall I'm loving the wifi speed all over my house, but one thing is driving me crazy... I have three Belkin WeMo switches ...
rhester72
Apr 09, 2017Virtuoso
It sounds like it isn't letting go of its old lease - which is odd if you did indeed do a factory reset (this has come up before).
Now that it's connected to guest (which should have cleared the lease), will it now connect to main?
Rodney
Retired_Member
Apr 10, 2017Nope :(
It consistently refuses to connect to the main network but happily connects to the guest one.
