Alf_G
Dec 08, 2018Aspirant
Device Set Up Question for Orbi RBK23
I'm considering replacing my Airport Extreme with an Orbi RBK23. The one thing holding me back is that in the years since I first set up the Airport my aquisition of WiFi dependent devices has explod...
- Dec 08, 2018
I also changed from Airport Extreme and Time Capsule to Orbi. :)
Most devices will automatically connect to Orbi if you keep the same SSID and password. The only devices I had issue with are one security camera (Netatmo) and the Logitech Harmony hubs which seem to also check the MAC address of the AP, but all my other devices (TV's, speakers, laptops, different hubs, ...) connected smoothly to Orbi when I used the same SSID and password as what was in the old system.
So I believe that you will still need to check the devices one by one and connect the ones that will have issues.
Good luck
JoeCymru
Dec 08, 2018Virtuoso
All of my devices connected using the same SSID. If you have an issue with one or two, sometimes just power cycling them will straighten it outwhen they attempt reconnection.
