ChuckieCheese
Nov 25, 2018Luminary
Device shown as "blocked" in Access Control but can still connect to Orbi and Internet
Model: RBK50 with 2 satellites
Firmware: v2.2.1.210
OS: Mac, iOS, Linux and proprietary (IoT devices)
Under Advanced --> Access Control, I have turned on
- Turn On Access Control
- Bloc...
ChuckieCheese
Dec 02, 2018Luminary
Sorry for the delay in responding. I didn't get an email when someone replied, so not sure what happened.
I confirm that when the UI show "blocked" for some devices, it indeed block those devices from connecting. Pretty much ANY new devices (Mac, iPad, IoT, Raspberry Pi, etc.) got blocked with the firmware 2.2.1.210.
All devices that were added PRIOR to firmware 2.2.1.210 are still connecting just fine.
EDIT: this is strange, but after allowing the device to connect, Orbi UI will show the device is now allowed. I logged out from Orbi and re-login and now that same device is shown as "Blocked" again. Here's what happened:
1). Advanced --> Security --> Access Control
2). A bunch of new devices are shown as "blocked"
3). Click on each "blocked" device and select "Allow"
4). UI refreshing and show the device is "Allowed"
5). Log out OR click on other areas within the UI (Administration, Advanced Setup, etc.)
6). Go back to no. 1
7). The same devices that I had allowed to connect is now blocked again (?!).
Another case:
3). Click on "blocked" Device1 and select "Allow"
4). UI refreshing and show Device1 is "Allowed"
5). Click on "blocked" Device2 and select "Allow"
6). UI refreshing and show the Device2 is "Allowed". However, Device1 is now shown as "Blocked"
ekhalil
Dec 02, 2018Master
I think I saw this when I used Access Control previously. A way to recover this is to decativate access control and then -if you want it- activate it again.
I would do the following:
- Go to ADVANCED >> Security >> Access Control
- Select all devices and click on Allow
- Click on Apply
- Unselect "Turn on Access Control" and select "Allow all new devices to connect" and then click on Apply
- Now you have Access Contol deactivated. Please go to another menu or log out an in and make sure that all is still Allowed.
- Now iff you want Access Control then select it and click Apply.
- ChuckieCheeseDec 02, 2018Luminary
I tried the steps above and the problem still exists. As soon as I enabled Access Control again, the new devices are blocked again (?!).
Just for testing, I downgraded to V2.1.4.16 and it worked as before, so I am sticking with this firmware for now.
PS: how do I disable firmware auto-update?
- ekhalilDec 02, 2018MasterPlease see here how to stop auto update:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1660866/highlight/true#M44919- ekhalilDec 02, 2018MasterAlso please have a look at this workaround for the access control issue from another user, please test if this can help:
https://community.netgear.com/t5/Orbi/Orbi-refuses-to-change-status-for-blocked-devices/m-p/1670534/highlight/true#M46491
