ChiefNomad's avatar
ChiefNomad
Devices jumping from router to satellite
Hi,
On the RBR50 Orbi system, is there a way to isolate a MacBook for example so that it only connects to the router and never jumps to one of the satellites? Or for example, keep one of the devices close to a satellite from jumping onto the router?
  • FURRYe38's avatar
    Are Daisy Chain, MIMO and Fast Roaming enabled? Try disabling these on the router, reboot and see how it goes...
    • ChiefNomad's avatar
      ChiefNomad
      I'll give those a shot and see what happens as a result. Will post back with an update once I try your suggestion. Thank you.
